*CE_SetGlobalSharedEntitySettings
Set the global shared entity management settings.
*CE_SetGlobalSharedEntitySettings setting value
HyperMesh Tcl Modify Command
setting
The name of the setting to update.
auto_register
Auto-register shared entities to the connectors during connector realization, HM binary import, solver deck import and FE absorb.
sharedent_cleanup_delete
Cleanup shared entities during connector+FE deletion.
sharedent_cleanup_unrealize
Cleanup shared entities during connector unrealization.
value
0 - Turn off
1 - Turn on
To turn on auto-registration:
*CE_SetGlobalSharedEntitySettings "auto_register" 1
   # Handle error
Version History
2017.1
