*surfacemarksplitwithsurface
Splits a group of surfaces with another surface
*surfacemarksplitwithsurface mark surface
HyperMesh Tcl Modify Command
mark
The ID of the mark containing the surfaces to be split.
surface
The surface used to split the other surfaces.
To split surfaces 10 and 20 with surface 5:
*createmark(surfaces,1) 10 20
*surfacemarksplitwithsurface(1,5)
None.
