*voxel_lattice_hex_mesh_fill_voids
Sets the mode for filling closed volumes during voxel creation.
*voxel_lattice_hex_mesh_fill_voids mode
HyperMesh Tcl Modify Command
This must be preceeded by a call to *voxel_lattice_hex_mesh_init and must be followed by a call to *voxel_lattice_hex_mesh_create.
mode
0 - Only intersected voxels are considered for computing the volumes.
1 - All the voxels are considered for computing the volumes.
To create voxels of size 10 for include components 100-110 and exclude components 200-203:
*voxel_lattice_hex_mesh_init 10
*voxel_lattice_hex_mesh_fill_voids 0
*createmark comps 1 100-110
*voxel_lattice_hex_mesh_add_entities comps 1 1
*createmark comps 2 200-203
*voxel_lattice_hex_mesh_remove_entities comps 2 1
*voxel_lattice_hex_mesh end
   # Handle error
Version History
2019.1
