*midsurface_combine_all_targets
Combines the targets for all the vertices of the surface to offset
*midsurface_combine_all_targets face display_only
HyperMesh Tcl Modify Command
face
The index of the surface to offset.
display_only
0 The combined targets are displayed and assigned to their corresponding vertices.
1 The combined targets are displayed but not assigned.
Users cannot manually employ this command, because HyperMesh must internally generate the index values (they cannot simply be typed in).
None.
