*replacenodes
Replaces or moves a node with another node.
*replacenodes node1_id node2_id mode location
HyperMesh Tcl Modify Command
This command replaces or moves a node with another node.
node1_id
The ID of the first node.
node2_id
The ID of the second node.
mode
0 - Move but do not replace.
1 - Move and replace.
location
0 - Move node1 to node2.
1 - Move node1 and node2 to their midpoint.
To move node 20 to node 200 without replacing:
*replacenodes 20 200 0 0
To move node 20 to node 200 with replacing:
*replacenodes 20 200 1 0
To move node 20 and node 200 to their midpoint with replacing:
*replacenodes 20 200 1 1
   # Handle error
