*modifyicelement
Modifies a dependent node of an IC element.
*modifyicelement id mode node_id
HyperMesh Tcl Modify Command
id
The ID of the IC element to modify.
mode
1 - Move up in the order
2 - Move down in the order
3 - Delete
node_id
The ID of the node to modify.
Create an IC element with independent node 15, and dependent nodes to 16, 17, 18, 19 with DOF’s 123, 345, 1234, 123456, then remove node 18:
*icelementcreate
*createintarray2d 2 4 16 17 18 19 123 345 1234 123456
*addicconnectivity 1 15 1 2 4
*modifyicelement 1 3 18
   # Handle error
Version History
14.0
