*hf_setTLPOL
Moves the specified line to the specified component and sets it as TL or POL.
*hf_setTLPOL suffix color line_id flag_TL flag_POL
HyperMesh Tcl Modify Command
This command moves the specified line to the specified component and sets it as TL or POL.
suffix
The component suffix.
color
The component color. Valid values are 1 through 64.
line_id
The ID of the line of interest.
flag_TL
Flag that indicates whether to set the line as TL. Valid values are:
  • 0 - Do not set as TL.
  • 1 - Set as TL.
flag_POL
Flag that indicates whether to set the line as POL. Valid values are:
  • 0 - Do not set as POL.
  • 1 - Set as POL.
To set line 22 like a TL into a component with suffix "TL":
*hf_setTLPOL "TL" 7 22 1 0
   # Handle error
Version History
11.0
