*mapgroupelementsfromshellstosolids
Maps base elements of group master/slave elements from shells to associated solids.
*mapgroupelementsfromshellstosolids mark_id
HyperMesh Tcl Modify Command
mark_id
The ID of the mark of groups to map. Valid values are 1 and 2.
Shell elements 1-4 completely overlap with a face of solid elements 5-8, each sharing 4 common nodes. The group "test" has master elements created on shell elements 1 2 3 4.
To map master elements in group "test" from shell elements to associated solid elements:
*createmark groups 1 "by name" test
*mapgroupelementsfromshellstosolids 1
   # Handle error
Version History
14.0
