*markercreate
Creates an MBD marker.
*markercreate name node_id syst_id sys_flag color
HyperMesh Tcl Modify Command
This command creates an MBD analysis marker.
name
The name of the marker.
node_id
The ID of the node that defines the location of the marker.
syst_id
The ID of the orientation coordinate system.
syst_flag
A flag for the coordinate system. A value of 0 indicates that the coordinate system will be blank.
color
The color of the marker.
To create a marker m1 at node ID 100 using coordinate system ID 10:
*markercreate "m1" 100 10 1 5
   # Handle error
Version History
10.0
