*CE_AddLinkEntitiesWithRules
Update connectors at the specified locations with rules.
*CE_AddLinkEntitiesWithRules connector_mark_id entity_type entity_mark_id entity_state ce_rules ce_le_rule tolerance_flag tolerance num_ents
HyperMesh Tcl Modify Command
This command updates connectors at the specified locations with rules.
connector_mark_id
The ID of the mark containing the connectors to update. Valid values are 1 and 2.
entity_type
Type of entity to be added to the connectors as links.
entity_mark_id
The ID of the mark containing the entities to use as links. Valid values are 1 and 2.
entity_state
The state of the link entities. Valid values are:
0 - Geometry.
1 - Elements.
ce_rules
Flag indicating when to make the links. Valid values are:
0 - Now.
1 - At realize.
ce_le_rule
Flag indicating how to make the links. Valid values are:
0 - None.
1 - Use ID.
2 - Use name.
tolerance_flag
Flag indicating whether to use the default tolerance. Valid values are:
0 - Use default.
1 - Use specified value.
tolerance
Used to add entities only within the given tolerance from the specified connector.
num_ents
Number of entities to add/update connector (connectors thickness (2T, 3T, etc.) value).
Examples
Update connectors 1 and 2 to add the nearest two out of four components specified, using a tolerance of 1.0. Components will be linked by IDs:
*createmark connectors 1 1 2
*createmark comps 1 21 23 24 27
*CE_AddLinkEntitiesWithRules 1 comps 2 1 1 1 1 1.0 2
   # Handle error
