*morphdomainsupdatecolor
Sets the color of selected domains.
*morphdomainsupdatecolor entity_type mark_id color
HyperMesh Tcl Modify Command
This command will update the color of selected domains to the specified color.
entity_type
Must be set to domains.
mark_id
The ID of the mark containing the domains. Valid values are 1 and 2.
color
The color of the domain. Valid values are 1 through 64.
To change the color of a number of domains to be violet:
*createmark domains 1 6 15 154 153 68 143 211 185 184 167
*morphdomainsupdatecolor domains 1 37
   # Handle error
Version History
12.0.110
