*deleteidrange
Deletes an ID range.
*deleteidrange submodel_type id shortname entity_type ?pool_id?
HyperMesh Tcl Modify Command
This command deletes an ID range for a submodel.
submodel_type
The type of submodel to delete the ID range for. Valid values are includes and includefiles.
id
The ID of the submodel. Not required if shortname is used.
shortname
The shortname of the submodel. Not required if id is used.
entity_type
The type of entity to delete the ID range for.
pool_id
The optional ID of the solver pool.
Examples
To delete an ID range for include 1 for components
*createidrange includes 1 "" comps
   # Handle error
Version History
12.0.110
2019 - Added new optional argument pool_id.
