hm_getoccupiedentitiesinrange
Returns the list of occupied IDs in a specific range.
hm_getoccupiedentitiesinrange entity_type pool_id range
HyperWorks Tcl Query Command
Returns the list of occupied IDs in a specific range. The values are returned as a compacted list using ranges and commas where applicable.
entity_type
The type of entity to query.
pool_id
The ID of the entity pool to query.
range
The ID range within the specified pool to query. This should be encapsulated in quotes.
To get the element IDs in use in pool 2 for the range 100-200:
hm_getoccupiedentitiesinrange elems 2 "100-200"
   # Handle error
Version History
14.0
