hm_latestentityid
Returns the ID of the last created entity
hm_latestentityid entity_type ?num?
HyperMesh Tcl Query Command
Returns the ID of the last created entity. An option is also available to return the ID of previously created entities (up to 99).
entity_type
The type of entity to return the last created ID for.
num (optional)
Queries a specific entity created previously before the last entity. The max is 99. Default is 0 (last entity).
Examples
To get the latest created component:
hm_latestentityid comps
To get the previous latest and first previous 10th created component:
*createmark lines 1 100
#Create two nodes on the line
*nodecreateonlines lines 1 2 0 0
#Get the last created node
set node1 [hm_latestentityid nodes]
#Get the first previously created node
set node2 [hm_latestentityid nodes]
   # Handle error
Version History
12.0
