hm_getnearbyentities
Finds entities nearby entities on an input mark.
hm_getnearbyentities inputentitytype=<input_entity_type> inputentitymark=<mark_id> outputentitytype={<output_entity_type1> ?<output_entity_type2> ... <output_entity_typeN>?} outputentitymark=<mark_id> radius=<value> ?nearby_search_method=<method>?
HyperMesh Tcl Query Command
The options may be provided in any order.
The input entity type to find nearby entities to. Valid values are comps, elems, equations, loads, nodes, systems and vectors.
The ID of the mark of input entities. Valid values are 1 and 2.
The list of output entity types to find. Valid values are comps, elems, equations, loads, systems and vectors.
The ID of the mark of output entities. Valid values are 1 and 2.
radius=<value>
The nearby search radius/size.
The optional search method, either box or sphere (default).
Examples
To query loads and elements nearby comps 301 and 302 using a sphere of size 100:
*createmark comps 1 "by id only" 301 302
hm_getnearbyentities inputentitytype=comps inputentitymark=1 outputentitytypes={loads elems} outputentitymark=2 radius=100 nearby_search_method=sphere
   # Handle error
Version History
2020
