hm_getprincipalaxes
Returns the principal axes direction cosines for the selected entities.
hm_getprincipalaxes entity_type mark_id ?location_flag?
HyperMesh Tcl Query Command
Returns the principal axes direction cosine values for the selected entities. The values are always returned relative to the global axes. The values are returned as 1st_direction_x 1st_direction_y 1st_direction_z 2nd_direction_x 2nd_direction_y 2nd_direction_z 3rd_direction_x 3rd_direction_y 3rd_direction_z.
entity_type
The type of entity to query. Currently supported for comps and elems.
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
location_flag
Optional. Specifies the location about which the principal axes are calculated. Valid values are:
0 - Global (0,0,0). Default.
1 - COG location.
To get the principal axes for components 1-5:
*createmark comps 1 1-5
hm_getprincipalaxes comps 1
   # Handle error
Version History
11.0.101
