hm_historysupporttofile
Writes out to a file the commands that are supported for history.
hm_historysupporttofile filename support_level
HyperMesh Tcl Query Command
filename
The full path and file name of the output file.
support_level
The type of history support to write the commands for. Valid values are:
-1 - Commands that do not modify the database and therefore do not affect history
0 - Commands that are not supported for history
1 - Commands that are supported for history
To write out the list of unsupported commands to C:\temp\unsupported.txt:
hm_historysupporttofile C:/temp/unsupported.txt 0
   # Handle error
Version History
14.0
