hm_getlinelineangle
Returns the angle between two lines at one of their intersection points.
hm_getlinelineangle line_id1 line_id2 x y z
HyperMesh Tcl Query Command
Returns the angle between two lines at one of their intersection points. If the specified point is found to be on both lines, then it calculates the angle between the lines at this point and returns its value in degrees. Otherwise, an error is returned.
line_id1
The ID of the first line.
line_id2
The ID of the second line.
x y z
The coordinates of the intersection point.
To find the angle between line 43 and line 58 at point (4.7, 6.88, 9.4):
hm_getlinelineangle 43 58 4.7 6.88 9.4
   # Handle error
