hm_isentitydatanameparameterized
Determines if a specific data name or attribute is parameterized.
hm_isentitydatanameparameterized entity_type id data_name_or_attribute ?row_index? ?column_index?
HyperMesh Tcl Query Command
Determines if a specific data name or attribute is parameterized. A return value of 0 means it is not parameterized. A return value of 1 means it is parameterized.
entity_type
The type of entity to query.
id
The ID of the entity to query.
The data name or template attribute name/ID to query.
row_index (optional)
Row index for a 1D or 2D array. For a 1D array, it checks the parameterization at the specified row index. For a 2D array, it will check for the entire row.
This should be blank for non-array data names/attributes.
column_index (optional)
Column index for a 2D array. Used together with row_index, it checks the parameterization at the specified row_index and column_index.
To check the parameterization of attribute with name LSD_DA1 for entity set 5:
hm_isentitydatanameparameterized sets 5 LSD_DA1
   # Handle error
Version History
14.0
