hm_getwrappoints
Returns a list of points, from the first input point to the third input point, that trace a convex path across the specified entities.
hm_getwrappoints entity_type mark_id x1 y1 z1 x2 y2 z2 x3 y3 z3
HyperMesh Tcl Query Command
Given a mark of entities, a plane definition, and a vector, returns the maximum and minimum coordinates on the cross-section defined by the virtual intersection of the entities with the plane, in the vector direction.
entity_type
The type of entities to consider. Valid values are elems, surfs and comps (elems take priority over surfs).
mark_id
The ID of the mark containing the input entities.
x1
y1
z1
Defines the normal coordinates of the first input point.
x2
y2
z2
Defines the normal coordinates of the second input point.
x3
y3
z3
Defines the normal coordinates of the third input point.
To get the wrap points for all displayed elements using input points (0,0,0) (10,0,0) (10,10,0):
*createmark elems 1 displayed
hm_getwrappoints elems 1 0 0 0 10 0 0 10 10 0
   # Handle error
Version History
12.0.110
