hm_getverticesfromedge
Get surface edge endpoints.
hm_getverticesfromedge edgeID
HyperMesh Tcl Query Command
edgeID
The ID of the surface edge.
List containing two IDs of edge endpoints.
hm_getverticesfromedge 12
For a closed edge that starts and ends at the same point, the returned list still contains two entries, both equal to the same point ID.
The points order in the returned list reflects the parametric direction of the edge; the first point corresponds to the smallest parameter value.
None.
