hm_getmodelcheckresultentids
Returns the entity IDs for the specified Model Check check display name.
hm_getmodelcheckresultentids display_name
HyperMesh Tcl GUI Command
display_name
The check display name.
To get the entity IDs for the check named "Unused Materials":
set ids [hm_getmodelcheckresultentids "Unused Materials"]
   # Handle error
Version History
11.0.101
