hm_entitygettype
Returns the user-assigned entity type. The user-assigned entity type is set in the template.
hm_entitygettype entity_type entity_name_or_id searchType
HyperMesh Tcl Query Command
entity_type
The type of the queried entity.
entity_name_or_id
The name or ID of the queried entity.
searchType
By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. The two options are:
-byname: search only by name
-byid: search only by ID
None.
