hm_getedgesfromvertex
Returns all surface edges connected to a specified vertex point.
hm_getedgesfromvertex point_id
HyperMesh Tcl Query Command
This command returns all surface edges connected to a specified vertex point.
point_id
The ID of the vertex point.
To get the edges attached to vertex point with ID 2:
hm_getedgesfromvertex 2
   # Handle error
