hm_ce_linkprojectionorderget
Returns ordered projection information from links of spot connectors.
hm_ce_linkprojectionorderget mark_or_id option flag
HyperMesh Tcl Query Command
mark_or_id
The mark ID or connector ID to query.
option
0 - Return stored projection information with spot connector(s)
1 - Redo projection for spot connector(s) and return projection information
flag
id - mark_or_id is an ID
mark - mark_or_id is a mark
Examples
To get projection information from spot connector of ID 101:
set proj_infos [hm_ce_linkprojectionorderget 101 1 id]
   # Handle error
Version History
2021
