hm_getclosestpointsbetweentwolines
Find the shortest distance between two lines and return line points corresponding to this distance.
hm_getclosestpointsbetweentwolines lineID1 lineID2
HyperMesh Tcl Query Command
lineID1
ID of the first line.
lineID2
ID of the second line.
The result is returned as a list: { x1 y1 z1 x2 y2 z2}
Where "x1", "y1", "z1" are coordinates of the closest point on the first line and "x2", "y2", "z2" are coordinates of the closest point on the second line.
To find closest points between lines with id 1 and 2:
hm_getclosestpointsbetweentwolines 1 2
2.682E+003 -7.365E+002 6.050E+002 2.685E+003 -7.350E+002 6.040E+002
None.
