hm_checkproximity
Checks proximity between elements/components.
hm_checkproximity entity_type mark_id max_proximity ?mode? ?check_side? ?proximity_scheme? ?proximity_by_edge? ?min_angle_limit? ?max_angle_limit?
HyperMesh Tcl Query Command
Checks proximity between input entities and returns list of entities within the specified proximity. The output depends on the mode argument as defined below.
entity_type
The type of entity to check. Valid values are elems and comps (only elems in comps are considered).
mark_id
The ID of the mark containing the entities to check. Valid values are 1 and 2.
max_proximity
The maximum distance beyond which an entity is not considered.
mode
1 - Global proximity (default)
2 - Proximity between components (entity_type must be comps)
3 - Self proximity within components (entity_type must be comps)
When set to 1, returns two lists of element IDs. The first list contains the elements for which a proximity is found. The second list contains the paired elements for the elements in the first list.
  • E.g. {1, 2, 3, 4}{6, 6, 1, 1}
When set to 2 or 3, returns one list per input component. The first item in each list is the component ID. The first sub-list contains elements for which proximity is found. The second sub-list contains the paired elements.
When set to 2:
  • E.g. {compid1, {elements within proximity} {paired elements from other components}} {compid2, {elements within proximity} {paired elements from other components}} etc.
When set to 3:
  • E.g. {compid1, {elements within proximity} {paired elements from same component}} {compid2, {elements within proximity} {paired elements from same component}} etc.
check_side
1 - Check both sides of elements
2 - Check only the element normal side
3 - Check 'outward volume' side (default)
4 - Check 'inward volume' side
proximity_scheme
0 - Checks basic proximity along a ray from the element center along the normal direction.
1 - Checks comprehensive proximity. Reports any proximity within an imaginary offsetted volume of the element (default behaviour if not specified).
proximity_by_edge
0 - Ignores proximity for nearby edges (default behaviour if not specified).
1 - Considers proximity for nearby edges.
min_angle_limit
If the angle between the proximate element pairs is less than this value, such pairs are not reported.
max_angle_limit
If the angle between the proximate element pairs is greater than this value, such pairs are not reported.
To find proximity between all components using a max distance of 2.5:
*createmark comps 1 all
hm_checkproximity comps 1 2.5
{{201 200 199 198 197 196 195 194 225 224 223 222 221 220 219 218} {221 219 220 218 225 223 224 222 197 195 196 194 201 199 200 198}}
   # Handle error
Version History
13.0.110
2019 - Added new optional arguments proximity_scheme and proximity_by_edge. Changed default beahvior of API to use proximity_scheme value 1.
2019.1 - Added new optional arguments min_angle_limit and max_angle_limit.
