hm_ce_getconnectorcontrollist
Returns a list of connector controls or connector control defaults.
hm_ce_getconnectorcontrollist solver style option
HyperMesh Tcl Query Command
Returns a list of connector controls or connector control defaults for a given solver and style.
solver
The solver name.
style
The connector style. Valid values are app_mass, area, bolt, seam and spot.
option
0 - Return both connector control and connector control default
1 - Return connector control default only
2 - Return connector control only
Examples
To get connector control for solver nastran and style spot:
set ctrl_list [hm_ce_getconnectorcontrollist nastran spot 2]
   # Handle error
Version History
2021
