hm_getentityname
Returns the full HyperMesh entity type name for the passed entity type ID.
hm_getentityname entity_type_id
HyperMesh Tcl Query Command
This command returns the fully qualified HyperMesh entity name for the specified entity_type_id. Each entity type in HyperMesh is assigned a unique ID. This ID is converted to the entity type name using this command.
If entity_type_id is not valid, undefined will be returned.
This is the inverse of the hm_getentitytype command.
entity_type_id
The unique entity type ID.
Examples
To get the name of entity type 1 (nodes):
hm_getentityname 1
To get the name of entity type 11 (properties):
hm_getentityname 11
None.
