Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
The functionality of the HyperMesh Tcl Modify Command commands are available through Tcl. Additionally, commands that allow you to extract information from the HyperWorks Desktop database, such as entity ID numbers on a mark, a list of assemblies, component names, elements per component, nodes per
element, node values, and so forth. These are known as HyperMesh Tcl Query Command commands. They are used to query information from the database or template system.
Get information about all entities of the given type in the current model. A single call returns a list where every HyperMesh entity of the specified type (currently only assemblies, components, multibodies, materials, and properties are supported)
is represented with a single list item. Each list item is identical to the return value of the command, hm_entityinfo all for that entity.
Returns the hierarchical structure of assemblies, and optionally standalone components and multibodies, along with properties,
materials, groups and beamsection collectors.
Finds nodes which lie on or within shells or solid faces, or which can be projected on to those shells or solid faces
along a vector or element normal.
Returns a list {x y z} which describes the given entity’s absolute rotation. If HyperMesh is unable to locate the associated systems, the list will contain three empty members.
Gets the coordinates of the points for which normalized parameters are specified, along with the ID of the line on which
they are located, as arguments to the command.
Returns the closest point, the components of the tangent vector and the angle between the tangent vector and the z-axis
at the point on the line closest to the input coordinates.
Calculate and return the 3 moment of inertia (Ixx, Iyy, Izz) and 3 product of inertia (Ixy/Iyx, Iyz/Izy, Ixz/Izx) values
(MOI) for a single solid geometric entity.
Returns the arc angle of a specified edge domain. Optional arguments allow the arc angle to be calculated using a line,
node, or base point and axis to find the center of curvature.
Returns the radius of a specified edge domain. Optional arguments allow the radius to be calculated using a line, node,
Finds the difference of two HyperMesh tables of the same entity type (subtracts the contents of the second table from the first table) and places the result
in the first table.
hm_ae_getfe
Returns the elements from the realized attachment.
hm_ae_state
Return the current state of an attachment.
hm_allentitiesinfo
Get information about all entities of the given type in the current model. A single call returns a list where every HyperMesh entity of the specified type (currently only assemblies, components, multibodies, materials, and properties are supported) is represented with a single list item. Each list item is identical to the return value of the command, hm_entityinfo all for that entity.
hm_answernext
Provides an answer to the next command for Tcl scripts.
hm_appendmark
Appends entities on a mark based on user supplied options.
hm_assemlist
Returns the hierarchical structure of assemblies, and optionally standalone components and multibodies, along with properties, materials, groups and beamsection collectors.
hm_attributebehavior
Returns the behavior flag of an attribute on an entity for the current template.
hm_attributeentitytype
Returns the entity type number of an entity attribute on an entity for the current template.
hm_attributeentitytypename
Returns the entity type string of an entity attribute on an entity for the current template.
hm_attributeidentifier
Returns the identifier flag of an attribute on an entity for the current template.
hm_attributeidfromname
Returns an attribute ID from the attribute name for the current template.
hm_ce_cfglistget
Returns info on FE configurations for a specified solver, connector style and FE config file.
hm_ce_checklinkentities
Returns the names or IDs of entities added to the connector that currently do not exist in the database.
hm_ce_checkprojection
Check if the connectors make projection. Returns the failed connector IDs.
hm_ce_close_mcf
Ends the process of reading a master connector file, triggered by hm_ce_read_mcf.
hm_ce_datalist
Returns, in a list, all connector data displayed in the table for a single connector on mark and as a list of lists for multiple connectors.
hm_compareentitiessameside
Generates comparison results for entities positioned at the same location. This must be preceded by a call to hm_compareinit.
hm_compareentitiessymmetry
Generates comparison results for entities positioned symmetrically about a plane.
hm_excludebeyond
Removes entities from the base mark which are beyond the given distance or number of element rows from the entities on the target mark.
hm_exportidmgr
Exports the ID manager rules to a CSV or XML file.
hm_findnarrowsurfaces
Returns the list of narrow surfaces, including large surfaces with narrow tails or local narrow neck regions.
hm_findprojected
Finds nodes which lie on or within shells or solid faces, or which can be projected on to those shells or solid faces along a vector or element normal.
hm_getabsoluterotationvector
hm_getcardimageoptions
Returns information about certain options supported by a card image.
hm_getcardmark
This command returns the IDs (from the CARDINPUTLIST) for the entity type specified.
hm_getcentroid
Returns the geometric centroid for selected entities.
hm_getcleanupglobalflags
Returns the global flags currently being used for switching of some default modes for geometry autocleanup, element cleanup and element QI smoothing.
hm_getclosestnode
Returns the ID of the closest node to the point (x,y,z). Zero is returned if there are no nodes in the database.
hm_getclosestpointsbetweenlinesurface
Find the shortest distance between a line and a surface, and return line and surface points corresponding to this distance.
hm_getcommandfile
Returns the full path and file name of the command file.
hm_getconfigtypecountincol
Returns a list indicating the entity config, type and count values that are contained in a collector.
hm_getconfigtypeincol
Returns a list indicating the entity config and type values that are contained in a collector.
hm_getconnected2delems
Returns lists of 2D shell elements and nodes that form t-connections or share edges at component/material/property boundaries.
hm_getcoordinatesfromnearestsurface
Finds coordinates of a point that belongs to one of surfaces in input set and is a closest point to the location specified in command input.
hm_getcoordinatesofpointsonline
Gets the coordinates of the points for which normalized parameters are specified, along with the ID of the line on which they are located, as arguments to the command.
hm_getcriteria
Query the values of global mesh quality criteria.
hm_getentitycardimagedictionary
Returns a list of card images for the specified entity type and card image organizational type defined in the current template.
hm_getentitycreationid
Returns a valid entity ID that can be used to renumber both the creating and mapping entities.
hm_getentityinfo
hm_getentityname
Returns the full HyperMesh entity type name for the passed entity type ID.
hm_getentityroot
Returns the ID of the root entity for a given modular entity type.
hm_getentitytype
Returns the HyperWorks Desktop entity type ID for the passed entity type name.
hm_getentitytypealiasname
Returns the alias name for a specified entity type in the current user profile.
hm_getentitytypedictionary
Returns a list of card image types defined in the current template for the specified entity type.
hm_gethmfileuserprofile
Returns the user profile information saved in the HyperMesh database.
hm_gethmfileversion
Returns the binary file version string for a specified HyperMesh database.
hm_getidpoolnumber
Returns the ID pool number for a given solver and ID pool name.
hm_getidpools
Returns a list of pool IDs or names for the specified entity type.
hm_getidpoolsforidrange
Returns a list of pool names based on the specified entity type and solver ID range.
hm_getincludeentities
Selects entities and returns the entity types contained in a specified include file.
hm_getincludeisolationentitiesmark
Returns the entities referenced/cross-referenced by the selected components, for include file organization purposes.
hm_getlinelineangle
Returns the angle between two lines at one of their intersection points.
hm_getlinepointsatdistance
For a given line, test point, and distance, this command finds all of the line points that are at the specified distance from the test point.
hm_getlinetangentatcoordinate
Returns the closest point, the components of the tangent vector and the angle between the tangent vector and the z-axis at the point on the line closest to the input coordinates.
hm_getlinetgendpoint
Returns the components of the tangent vector and the angle between the tangent vector and the z-axis at the line end point.
hm_getlinetgstartpoint
Returns the components of the tangent vector and the angle between the tangent vector and the z-axis at the line start point.
hm_getmoi
Returns the tensorial moment-of-inertia values for the selected entities.
hm_getmoiofsolid
Calculate and return the 3 moment of inertia (Ixx, Iyy, Izz) and 3 product of inertia (Ixy/Iyx, Iyz/Izy, Ixz/Izx) values (MOI) for a single solid geometric entity.
hm_getmydocumentsdir
Returns the path to the current user’s "My Documents" folder on Windows.
hm_getsolidboundsforsurface
Returns a list of bounding surface IDs, one list for each set of bounding surfaces found, or nothing if there is not a valid closed bounds found.
hm_getsurfacefromface
Gets the surface containing the face whose ID is supplied as the argument.
hm_getsurfacenormal
Gets the normals of the surfaces connected to the node or point whose ID is given as the argument.
hm_getsurfacenormalatcoordinate
Returns the closest point and the components of the normal vector at the point on the surface closest to the input coordinates.
hm_getsurfacesbyarea
Gets the surfaces with an area smaller or equal to the specified value.
hm_getsurfacesbyedgelength
Gets the surfaces that have an edge with a length smaller or equal to the specified value.
hm_getsurfacesfromedge
Gets all surfaces connected to the edge whose ID is supplied as the argument.
hm_getsurfacesfromsolid
Returns the list of surface IDs associated with a specified solid ID.
hm_getsurfacesfromvertex
Gets all surfaces connected to the point whose ID is supplied as the argument.
hm_getwrappoints
Returns a list of points, from the first input point to the third input point, that trace a convex path across the specified entities.
hm_hierarchy
Returns the hierarchical structure of assemblies, components and multibodies, along with properties, materials, groups and beamsection collectors.
hm_morph_getdomainangle
Returns the angle between two specified edge domains. Optional argument allows the user to input a normal vector to be used to measure the angle.
hm_morph_getdomainarcangle
Returns the arc angle of a specified edge domain. Optional arguments allow the arc angle to be calculated using a line, node, or base point and axis to find the center of curvature.
hm_morph_getdomainlength
Returns the length of a specified edge domain. Optional argument allows the user to input a vector along which to measure the length.
hm_morph_getdomainradius
Returns the radius of a specified edge domain. Optional arguments allow the radius to be calculated using a line, node, or base point and axis to find the center of curvature.
hm_morph_getmvolface
Returns the morph volume face ID for the specified morph volume and nodes along the edges of that face.
hm_morph_getnodehandle
Returns the handle ID for the specified node if a handle exists at that node.
hm_morphupdatecheck
Identifies changes in the database relevant to HyperMorph entities and calls the necessary commands to update those HyperMorph entities.
hm_pathmanager
Returns all search paths, and runs a specified procedure for each path.
hm_proximityinit
Checks the proximity between elements or components, and stores the results internally.
hm_proximityinitwithtarget
Checks the proximity between elements or components, allowing the user to specify the target, and stores the results internally.
hm_tableappend
Appends the contents of a HyperMesh table to another HyperMesh table of the same entity type. Creates a destination table if it does not exist.
hm_tablecopy
Makes a copy of the HyperMesh table. Overwrites destination table.
hm_tabledifference
Finds the difference of two HyperMesh tables of the same entity type (subtracts the contents of the second table from the first table) and places the result in the first table.
hm_tableintersection
Finds subset of entities common to two HyperMesh tables of the same entity type and places it into the first table.
hm_tablelist
List the names of all tables created by marktotable.
hm_tablelookup
Search a table for an entity ID. The constant 1 is returned if the ID is found. Otherwise, 0 is returned.
hm_tabletomark
Append the entity IDs from the named table to the specified mark.
hm_wadlinesgetleggridline
Returns a series of three doubles denoting the points for the line calculated by the previous call to hm_wadlinesgetgridpointsleg.
hm_wadlinesgetwadpointtapeline
Returns coordinate data defining a line made by the measuring tape running from the ground to the specified WAD point along the vehicle.
hm_wadlinesispointintestzone
Returns whether a point is inside a test zone by taking in the coordinates of the zone boundary.
hm_wadlinessetbumper
Sets the entities for the internal bumper components used for the internal bumper reference line and upper/lower leg grid point generation.
