hm_fe_getconfigfile
Returns the FE config file set for user-defined weld creation.
hm_fe_getconfigfile
HyperMesh Tcl Query Command
To get the global file set internally in HyperMesh:
set feconfigfile [ hm_fe_getconfigfile ];
This returns the .cfg file specified through the panel or through the command. This is specified only for user-defined FE creation.
