hm_getmarkfromtable
Returns the entity IDs from the specified table.
hm_getmarkfromtable table_name
HyperMesh Tcl Query Command
This command returns the list of entity IDs that exist in the table with table_name.
To create a table named elem_table containing elements in the component wingbox and retrieve the values from the table:
*createmark elems 1 all
hm_marktotable elems 1 elem_table
set elems [hm_getmarkfromtable elem_table]
If table_name is invalid, you will get the following error:
hm_getmarkfromtable: the table 'table_name' was not found.
   # Handle error
