hm_ce_getnumoffeprojinfo
Returns the number of projection data stored in the array (size of array).
HyperMesh Tcl Query Command
To get the number of projection data array size:
set num_of_projs [ hm_ce_getnumoffeprojinfo ];
This function should only be called from within a connector-registered property script (which is executed during connector FE realization). The projection data this function relies upon is removed immediately after connector FE realization.
The number of projection data array size is equal to the total number of welds created in the model.
