hm_modent_getcontentsbymark
Returns a mark of entities which are contents of a modular entity.
hm_modent_getcontentsbymark entity_type entity_id content_entity_type mark_id
HyperMesh Tcl Query Command
longDescription
entity_type
The modular entity type. Currently supported for subsystemconfigurations, subsystems and subsystemsets.
entity_id
The ID of the modular entity.
content_entity_type
The content entity type.
mark_id
The ID of the mark to return the content entities. Valid values are 1 and 2.
Examples
To get the components for subsystem 2 on mark 1:
hm_modent_getcontentsbymark subsystems 2 comps 1
   # Handle error
Version History
2020
