hm_getunoffsetablenodes
Saves to the user list the unoffsetable nodes. Useful for CFD BL meshing.
hm_getunoffsetablenodes entity_type mark_id angle_threshold
HyperMesh Tcl Query Command
Consider a node and all its surrounding elements. The visibility angle of an element is the signed angle between the node normal and the element normal after subtracting 90 degrees. The visibility angle of the node is the minimum of the element visibility angle for all surrounding elements. The best visibility angle of the node is the maximum of the node visibility angle for all choices on the node normal. A node having zero or negative best visibility angle is considered absolutely unoffsetable. A node having its best visibility angle less than angle_threshold is considered unoffsetable.
entity_type
The type of entity to query. Valid values are comps and elems.
mark_id
The ID of the mark containing the entities to query. Valid values are 1 and 2.
angle_threshold
A value >=0.0 and < 45.0 that defines the threshold visibility angle in degrees for determining a node is unoffsetable.
To find all unoffsetable nodes in comp1 using an angle threshold of 2.5:
*createmark comps 1 comp1
hm_getunoffsetablenodes comps 1 2.5
   # Handle error
Version History
14.0
