hm_tableintersection
Finds subset of entities common to two HyperMesh tables of the same entity type and places it into the first table.
hm_tableintersection table1 table2
HyperMesh Tcl Query Command
table1
First table.
table2
Second table.
TCL_OK(0) if successful.
TCL_ERROR(1) otherwise
This command can be used to find entities common for two HyperMesh tables.
# Creating 2 tables
*createmark comp 1 1 2
hm_marktotable comp 1 t12
*createmark comp 1 2 3
hm_marktotable comp 1 t23
# Copying table
hm_tablecopy t12 tcom;
hm_tableintersection tcom t23;
# tcom contains comp 2 now
None.
