hm_fe_setdvstfile
Set the diameter versus thickness file for user-defined welds.
hm_fe_setdvstfile dvstfile
HyperMesh Tcl Query Command
dvstfile
The name of the diameter-thickness file.
To set the diameter versus thickness file:
set dtfile "d:\my_dvst_file.txt"
hm_fe_setdvstfile $dtfile;
This is stored globally and is applicable to all the connectors realized using the user-defined weld option. The diameter is used for creating ACM or CWELD.
None.
