hm_getinternalidlist
Returns the internal HyperMesh IDs for a list of solver IDs and a solver ID pool.
hm_getinternalidlist id_pool solver_id_list ?search_type?
HyperMesh Tcl Query Command
This command returns the internal HyperMesh IDs for a list of solver IDs and a solver ID pool. This command is only applicable to templates and entity types that have ID pools.
id_pool
The pool ID or name. By default, the value is assumed to be the pool ID. This is controlled by the optional search_type argument.
solver_id_list
The list of solver IDs to query. All IDs must belong to the specified pool.
search_type
Defines whether id_pool is specified as a pool name or a pool ID. Valid values are -bypoolid and -bypoolname. If not specified, it defaults to -bypoolid.
Examples
To get the internal HM IDs of pool ID 1 and solver IDs 2, 3 and 4:
hm_getinternalidlist 1 "2 3 4"
or
hm_getinternalidlist 1 "2 3 4" -bypoolid
To get the internal HM IDs of pool PROP_IDPOOL and solver IDs 17 and 20:
hm_getinternalidlist PROP_IDPOOL "17 20" -bypoolname
   # Handle error
Version History
12.0.110
