hm_comparesetreviewcolor
Sets the graphical review color for comparison results.
hm_comparesetreviewcolor match_type match_location color
HyperMesh Tcl Query Command
Sets the graphical review color for comparison results. This must be followed by a call to hm_comparesetreview to refresh the graphics.
match_type
The type of match to set the color for. Valid values are:
0 - Unmatched
1 - Topological
2 - Intersected
3 - Overlapped
4 - Matched
match_location
The location of the entities to set the color for. Valid values are:
1 - Source entities
2 - Target entities
color
A color value from 1-64.
To set the review colors for unmatched entities to black for both source and target entities for a same side comparison of elems 1-20 and 101-120:
*createmark elems 1 1-20
*createmark elems 2 101-120
hm_compareinit
hm_compareentitiessameside surfs 1 surfs 2 0.1 2 0:
hm_comparesetreviewcolor 0 1 1
hm_comparesetreviewcolor 0 2 1
hm_comparesetreview 1
hm_compareend
   # Handle error
Version History
12.0
