hm_setmodelcheckcheckstatus
Sets the run status for the specified Model Check check display name.
hm_setmodelcheckcheckstatus display_name status
HyperMesh Tcl GUI Command
display_name
The check display name.
status
  • 0 - Not run
  • 1- Run and found failed entities
  • 2 -Run and found no failed entities
  • 3 - No relevant entities found in the model
To set the run status for the check named "Unused Materials" to run (1):
hm_setmodelcheckcheckstatus "Unused Materials" 1
   # Handle error
Version History
11.0.101
2019 - Added new status value 3.
