hm_getnodalthickness
Gets the thickness of the node whose ID is given as the argument.
hm_getnodalthickness entityType nodeID
HyperMesh Tcl Query Command
entityType
The type of the entity. Only nodes are currently supported.
nodeID
ID of the node.
This function queries the surface definition to obtain the thickness at a given node location. To obtain the thickness value using this function, the node should be associated with a geometric surface that was created using midsurface extraction tools in HyperMesh. The function returns "-1" if the thickness at that location could not be obtained.
hm_getnodalthickness node 73
None.
