hm_getnodessharedbyothercomps
Returns the nodes on the input components that are shared by other components.
hm_getnodessharedbyothercomps comp_mark_id node_mark_id exclude
HyperMesh Tcl Query Command
This command returns the nodes on the input components that are shared by other components.
comp_mark_id
The ID of the mark containing the components with the nodes of interest. Valid values are 1 and 2.
node_mark_id
exclude
0 - Do not exclude any nodes.
1 - Exclude nodes on mass, rigid and joint elements.
To find the nodes from component 100 shared by other components:
*createmark comps 1 100
hm_getnodessharedbyothercomps 1 1 0
   # Handle error
Version History
11.0.101
