hm_ce_getunsyncdata
Returns data which are not synchronized from the connectorcontrol assigned to a connector.
hm_ce_getunsyncdata id option
HyperMesh Tcl Query Command
id
The ID of the connector to query.
option
0 - Returns common data
1 - Returns unique data on connector
2 - Returns unique data on connectorcontrol
Examples
To get unique data from the connector with ID 101:
set unique_data [hm_ce_getunsyncdata 101 1]
   # Handle error
Version History
2021
