hm_getangle
Returns the angle between three nodes/points.
hm_getangle entity_type id1 id2 id3
HyperMesh Tcl Query Command
entity_type
The type of entity to query. Valid values are nodes and points.
id1
The ID of the first entity.
id2
The ID of the second entity.
id3
The ID of the third entity.
To get the angle between nodes 100, 101 and 102:
hm_getangle nodes 100 101 102
   # Handle error
Version History
10.0
