hm_fe_getdvstfile
Returns the dvst file set for weld or property creation.
hm_fe_getdvstfile
HyperMesh Tcl Query Command
The diameter vs. thickness is the global file set internally from the panel or through the commands.
To get the diameter vs. thickness file:
set dtfile [ hm_fe_getdvstfile ];
None.
