hm_me_entitiesall
Returns all of the entity types and IDs contained in a module.
hm_me_entitiesall id
HyperWorks Tcl Query Command
Returns all of the entity types and IDs contained in a module. The return is a list of lists, with the first value in each sublist being the entity type, and the remaining values being the entity IDs. For example:
{props 1 2} {mats 5} {elems 100 101 102} {nodes 100 101 102 103 104 105}
id
The ID of the module to query.
To get the entities contained in module 10:
hm_me_entitiesall 10
   # Handle error
Version History
2017.1
