*ME_ModulePopulate
Moves entities from one module to another.
*ME_ModulePopulate id reserved entity_type mark_id
HyperMesh Tcl Modify Command
id
The ID of the module part to move the entities to.
reserved
Reserved for future use. Must be set as "".
entity_type
The type of entity to move.
mark_id
The ID of the mark containing the entities to move. Valid values are 1 and 2.
Move comps 22-24 to module part 168:
*createmark comps 1 22-24
*ME_ModulePopulate 168 "" comps 1
   # Handle error
Version History
14.0
