*createcontrolvol
Creates an airbag control volume.
*createcontrolvol entities markmask name
HyperMesh Tcl Modify Command
entities
Control volumes are created using elements.
markmask
Source of elements used to create control volume.
1 - Elements selected by the user.
name
Name of the control volume.
Examples
To create a control volume called "airbag" using the elements that you selected:
*createcontrolvol(elements,1,"airbag")
