*ExportAssemblyAndGlobalEntities
Exports part assembly and child data.
*ExportAssemblyAndGlobalEntities file_path
HyperMesh Tcl Modify Command
file_path
The location to write to.
Examples
To export to C:/temp:
*ExportAssemblyAndGlobalEntities "C:/temp"
   # Handle error
Version History
2020
