*exportbif
Exports the current database to Medina .bif format.
*exportbif filename
HyperMesh Tcl Modify Command
Exports the current database to Medina .bif format. Currently only nodes, elements, node sets and element sets are supported.
filename
The full path and file name to export to.
To export to a file named C:/temp/test.bif:
*exportbif C:/temp/test.bif
   # Handle error
Version History
13.0
